Bizhub c452
  • konica7022
    • Nov 2008
    • 132
    Bizhub c452
    Hi guys
    i have blue color dirt marks before the end of the page,
    i checked all the drums and transfer belt all clean cant figure out where its coming from? could it be fuser?
    i printed and uploaded the print pattern, kindly through some light.
  • ni311
    • May 2008
    • 658
    Re: Bizhub c452
    Are you sure it is blue? Think about it, if it would be the fusing unit, you should have only one color...
    Konica Minolta Error Codes - Explanations and Solutions
    • allan
      RTFM!!
      • 5462
      Re: Bizhub c452
      This one is easy.
      The IU's are toast.
      Remember to clean the laser slit glass when replacing the IU's.
      Check the condition of the transfer belt and fuser.
      Or...
      You can disassemble the IU's and clean the corona units and doctor blades.
      Mmm there is a tricky seal that breaks.
      Whatever
      • allan
        RTFM!!
        • 5462
        Re: Bizhub c452
        Did not even know the machine can produce that print. Rather show the CMYK halftones at 127 and 255.
        Whatever
        • konica7022
          • Nov 2008
          • 132
          Re: Bizhub c452
          Originally posted by allan
          This one is easy.
          The IU's are toast.
          Or...
          well i cleaned the whole machine (without disassembling any component) then did image initialization and stabilization
          but it is the blue color for sure and some time wont come sometime will show up more
            • 15062
            Re: Bizhub c452
            It looks like one of your printheads is out of alignment. Fix that first and see if you still have the problem.
            • konica7022
              • Nov 2008
              • 132
              Re: Bizhub c452
              Another one enhanced image
              • allan
                RTFM!!
                • 5462
                Re: Bizhub c452
                P-codes?
                Inspect your cyan drum.
                Whatever
                • konica7022
                  • Nov 2008
                  • 132
                  Re: Bizhub c452
                  P-codes?
                  no p codes, except the oil can & !
                  i cant find any stains on the blue drum its neat and clean, even moving it by hand wont show any residue cyan toner
                  • mo0651
                    • 1054
                    Re: Bizhub c452
                    when you touch the oil can, what's it tell you. Is that a new cyan IU ?
                    • konica7022
                      • Nov 2008
                      • 132
                      Re: Bizhub c452
                      oil can says "machine status L-4 "
                      cyan IU is one block away from end of life
                      black IU reach end of life but still works fine
                      • mo0651
                        • 1054
                        Re: Bizhub c452
                        L-4 is black drum life warning.... Cyan drum is probably just wore out. They do fail prematurely every now and then. if you run a stabilization does it go away for a few copies??
                        • wseyller
                          • Sep 2012
                          • 1129
                          Re: Bizhub c452
                          Do a half stop test. If defect on cyan drum I would replace cyan IU. Seems clear to me that is probably the issue.
                          Sent from my XT1254 using Tapatalk
                          • konica7022
                            • Nov 2008
                            • 132
                            Re: Bizhub c452
                            i did that still cant see any residue in cyan drum now TB
                            ii swaped cyan 452 with cyan C451 but it gave and error c-2451
                            i dont have an extra cyan C452 in hand
                            i am trying to arrange one
