Konica C552 "Obtain Device Information" Error
  • q555
    • May 2015
    • 81
    Hi,
    Good Day!
    I have a problem with Konica C552.
    Obtain Device Information Error
    SNMP is enable both port settings and MFP Settings.
    Actually, the main problem is I can't print if USER AUTHENTICATION is ON.
    I've tried to other machines with same model, and it works fine.
    What I've noticed is, if I click OBTAIN DEVICE INFORMATION, i got an error. So, I think, i can't communicate with the printer properly.
    Thanks for the help! Cheers!
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Konica C552 "Obtain Device Information" Error
    You'll need to manually enter the IP address instead of auto. You must uncheck auto for this to work.
    • emujo
      • Jun 2009
      • 3009
      Even if the auto button is unchecked, if the driver can't querry the MFP and pull the authentication info, you will never be able to print. It could be machine firmware/function version, and old driver version, or an SNMP issue. Double check your settings in the web page and verify that the SNMP settings are at the default "public" and you are not unknowingly using SNMP v3 (not sure if this is supported on the C452 though). Emujo
      • q555
        • May 2015
        • 81
        Hi,
        Yes, I've already tried this option. But still no luck.
        Thanks for the reply.
        • q555
          • May 2015
          • 81
          Hi,
          I've double check all the options. I've also copied the settings from other konica c552 that worked with user authentication. But still no luck . Any other option emujo?
          Thanks!
          • q555
            • May 2015
            • 81
            Originally posted by q555
            Hi,
            Thanks!
            I've also updated the firmware emujo, and same driver installed that I use with the other konica c552. I've also tried to different operating system.
            tried on both machines>> (1) konica c552 working with user authentication (windows 7 with 1.0 driver = working) & (windows 8.1 with 3.6 driver = working)
            (2) konica c552 not working with user authentication (windows 7 with 1.0 driver = not working) & (windows 8.1 with 3.6 driver = not working)
            • allan
              RTFM!!
              • 5462
              I would back-up the machine settings and do an all data clear in service mode. Remember to pull out all the toners and IU's before doing that.
              It will set all the network data back to default.
              Whatever
              • paulrid
                • Nov 2011
                • 206
                Hi,
                try a different network cable, I have had similar myself.
                paul.
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  I believe there is also a drop down for the particular model you want to be correct.
                  • peter42
                    • Jan 2012
                    • 110
                    Had this today, customer changed his 24 port switch to a Gb version some days ago.
                    Since then Bizhub has trouble with scan to folder, print was OK.
                    placed a 100Mb-switch between Bizhub and GB-Switch- no connection.
                    After investigation, the customers Cat5 line has a 350 Mhz-Mark on it:
                    Replaced cabel between Bizhub and GB-Switch with a new Cat5e shielded one.
                    Problem solved.
                    greetings Peter
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      Seen this with another manufacturer, there is a specific service that has to be running in order for the user authentication and obtain device info to work. Install the driver via the setup.exe and the service will be installed.
                      GL
                      • allan
                        RTFM!!
                        • 5462
                        If both User auth and account track it on that will obtain device settings does not work. don't know why but had that problem today.
                        Whatever
                        • emujo
                          • Jun 2009
                          • 3009
                          I have set up user authentication and account track on KM devices for the past 7 years, there is more info to enter when both methods are used, but I have never seen it fail due to a driver configuration failure. The original poster has not mentioned whether the device is at the proper function level for the driver version he/she is using. Emujo
