Bizhub 180 C0070 Error
  • adamcopiercali
    • Aug 2012
    • 88
    Bizhub 180 has a C0070 Error. I've read this may be related to the toner bottle motor but also the fuser is not heating, could they be related issue?
  • mo0651
    • 1054
    Re: Bizhub 180 C0070 Error
    toner bottle rotation... throwing the code before fuser can heat.
    • allan
      RTFM!!
      • 5462
      Not even cousens. Could just be bad luck. The only reason i have had that code was for leaving the motor or sensor unplugged.
      Whatever
      • allan
        RTFM!!
        • 5462
        To prove that chuck a little toner in the dev to satisfy the beats, and it should heat up.
        Or just fix the bottle rotation problem.
        Whatever
        • Blizzoo
          • Aug 2013
          • 608
          Customers tend to change the bottle when toner is supplying and force the new one in a wrong position making a mess.
