Konica C220 - Email subject
  • jonbonse
    • Jun 2009
    • 730
    Hi All
    I have a used KM C220 with someone else's company name in the subject line when you scan and send emails from it.
    When I log onto the copier via explorer as administrator, the email subject line is blank!
    Please can anyone help me clear this old company name?
  • emujo
    • Jun 2009
    • 3009
    Re: Konica C220 - Email subject
    Admin/Administrator Machine Settings/Admin address and Machine address. Subject line has nothing to do with from address. You can always do a network init to clear this info out though. Emujo
    • jonbonse
      • Jun 2009
      • 730
      its not the 'from' address that's the problem, it's the subject line of the email (or the message it puts in the email subject line)...............
      • emujo
        • Jun 2009
        • 3009
        Screenshot 2016-01-19 16.00.47.jpgSubject line info is programmed through the public user, not admin...Emujo
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          the current settings have been saved as default in scan mode - even if you change the subject in pswc it will stay as it was set previously at the panel. Change it in scan mode once corrected and then re-save the current settings as default.
          Had this yesterday and was reminded of this quirk.
          • jonbonse
            • Jun 2009
            • 730
            Thanks!
            How do I save as default once changed?
            • JDR
              • Jan 2015
              • 82
              scan/fax mode -> communication settings -> email settings -> subject -> write yours. -> "close" ->
              utilty/counter -> user settings -> scan/fax settings -> default scan/fax settings -> current setting -> "OK"
              • emujo
                • Jun 2009
                • 3009
                Good answer...think I'm going to like JDR...Emujo
