Konica Bizhub 423 ADF Problem
  • hood4472
    • Aug 2013
    • 17
    The problem is that when you use the ADF it is shifting the position of the copy intermittently. The shift is to the front or rear, not lead to trail. The distance varies when it happens but it isn't the same on every copy, nor does it happen on every copy. Just put in new ADF rollers. Any suggestions would be appreciated. Thanks in advance.
    Robin
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Konica Bizhub 423 ADF Problem
    Is the ADF height set properly?
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • minimerlin
      • 851
      Robin
      Was the fault present before you changed the rollers? Is the ADF level front to rear? Is the copy showing a skew?
      Please do not PM me without asking first.
      • hood4472
        • Aug 2013
        • 17
        The problem was there before we changed the rollers. We have not adjusted ADF height and or position. The entire copy is shifted but not skewed. And it is intermittent.
        • antone
          • Oct 2014
          • 344
          All trays...?
          • splblazer91
            • Jul 2014
            • 204
            slipping clutch?
            • Gaffers01
              • May 2011
              • 335
              Are you sure its actually the doc feeder?
              Have you taken copies from the glass?
                • 15005
                Have you gone into service mode and adjusted "original tray width" for the DF?
                • hood4472
                  • Aug 2013
                  • 17
                  We did make copies from the glass and those were fine. Otherwise we haven't made any adjustments to it yet. Since it was an odd problem we hadn't seen before we were trying to gather as many ideas as possible for going back out on the machine. Thanks for the all ideas and keep them coming if you have them. Thanks.
                  • emujo
                    • Jun 2009
                    • 3009
                    There is a special A4 test chart that comes with each MFP for adjusting the ADF. All of this is done through SM. The test chart allows for proper lead edge positioning front/rear, document stop front/rear and zoom calibrations. You can also calibrate the ADF tray min/max readings. Emujo
                    • hood4472
                      • Aug 2013
                      • 17
                      Is there a way to order the chart, we don't have one? Thanks for the help.
                      • emujo
                        • Jun 2009
                        • 3009
                        9J071XC048DA (the "1" may be an "I" or a "l" hard to tell by the parts manual). Emujo
                          • 15005
                          There are no "I"s in KonMin part numbers. They are always "ones". Also, there are no "O"s, they are always "zeros"
                          • allan
                            RTFM!!
                            • 5462
                            Ok so this happen with scans and not with prints too just to be clear its not the registration clutch.
                            Change the direction you scan the paper in from LEF to SEF. And see is the shift changes from SUB to MAIN scan.
                            Whatever
                            • emujo
                              • Jun 2009
                              • 3009
                              ADF testchartA4.pdf
                              OK here is the test chart, formatted for A4, all you need is some A4 paper and your set. part# is on the chart if needed. Emujo
