C3425 then C3B02 on C652 photocopier
  • Geoff Taylor
    • Jul 2025
    [Error Code] C3425 then C3B02 on C652 photocopier
    C3425 Fault , IH Power supply fuse blown.(IHPU)
    Replaced IH Power supply, Relay Drive board (REDB) and Printer Control PWB(PRCB)
    Did trouble Reset, Has new Fuser Assy
    Temperature readings were as such:
    middle temp 53
    heat protector 78
    heat edge 52
    soaking side 110
    machine sensor temperature 85
    Took heated fuser from another machine
    machine was ok for approximately 2 minutes then the power tripped and blew the IHPU fuse and came up with a C3B02 fault.
    I suspect the fault is a faulty Fixing coil.
    Smelled like the coil was burnt
    Haas anybody had a similar fault
  • Perfect
    • Jun 2015
    • 10
    Re: C3425 then C3B02 on C652 photocopier
    Change Induction Heater board IHPU they cost a little though, or replacing electrical component (transistor, boosters etc )
