Konica Minolta Bizhub C35b (Waste toner bottle is almost full) how to reset the error
  • wiedu
    • May 2011
    • 47
    Hello,
    my waste toner bottle for KM Bizhub C35P is almost full, I empty it but the error is still there,
    could I delete the message error or I have to replace it by a new one?
  • SmellsHot
    Head Tech
    • 512
    Re: Konica Minolta Bizhub C35b (Waste toner bottle is almost full) how to reset the e
    BUY A NEW ONE......They're cheap
    Otherwise you have to pry off the top and vacuum out the window and than glue the top back on
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • wiedu
      • May 2011
      • 47
      Many thanks
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Well, not really. Just drill a small hole in the clear full detection reservoir, blow it out so it's completely clean and put a small piece of tape over the hole. We've been doing it that way on any model with a similar waste box for years.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • allan
          RTFM!!
          • 5462
          I do the same thing.
          Turn the waste box upside down(empty it first). pull the small lever on top of the waste box straight on top of the lens and shake the toner out.
          If that does not state as ready on the stat page drill the hole. I have done that with a small PH0 screwdriver a blade or a scissor.
          Cant recall ever replacing one. Had to glue a gear back once.
          Whatever
          • wiedu
            • May 2011
            • 47
            Many thanks, good idea
            • Copiersupport
              • Jan 2016
              • 7
              Konica Minolta bizhub C25 Waste Toner Receptacle / Disposal Tank, Genuine (G1398)
              found Link Above where you can find disposal tank for under $25
              • SmellsHot
                Head Tech
                • 512
                No disrespect to you guys drilling a hole in the waste toner, but you obviously don't value your time. The most expensive waste toner is like $20....surely 3 minutes of your time and the possibility of spilling toner on your clothes is worth more than that........Unless you guys are getting a clothing allowance
                • andyf424
                  • Jun 2013
                  • 126
                  Pop the little clear plastic thing off and clean it. Messy, putzy job but only takes a minute.
                  I don't stock WTB's in the van and a lot of customers ignore the "replace WTB soon" message until the machine is down. Although we next day ship all supplies this inevitably happens when the customer has some super important/urgent thing to print and they are all worked up about their machine being down. Even though it's their fault, I'll clean out the box and get them running again.
                  I'd prefer they keep one on hand but, I'd also prefer they load paper correctly and keep staples out of the doc feeder.....
                  • allan
                    RTFM!!
                    • 5462
                    It takes less than 5 min to do.
                    Whatever
                    • Synaux
                      • Mar 2012
                      • 1224
                      I think they are more like 30.00 after shipping, etc.
                      Thats ~$360.00 an hour!
                      • solidzdawg
                        • 71
                        Spoken like a service manager :P jk
                        • saburnsjax
                          • Apr 2011
                          • 31
                          Thank you so much for the tip! Ours locked up with this message without any warning so we were stuck on a Saturday! Good temporary fix until the replacement bottles arrive!
