pro 951 7229 jam
  • splblazer91
    • Jul 2014
    • 204
    pro 951 7229 jam
    Paper stops in finisher transport section going to the bottom output tray. If i push everything to the top tray it runs fine. Tech support had me order 2 motors but i doubt that will resolve the issue. Any ideas?
  • antone
    • Oct 2014
    • 344
    Re: pro 951 7229 jam
    Try looking for solenoid gate
    • splblazer91
      • Jul 2014
      • 204
      Solenoids seem to function properly. Replaced entrance and exit motor. Still jams.
      • chucko71
        • 6
        I am also getting this same code on a bh951, J7229 code and stopping in the finisher mostly right after the hole punch unit. Was there a solution to this problem, Ive already tried multiple solutions from the call center with no luck. I can run about 200 or so copies before the first jam then its pretty consistant after that. Also feeding to the top exit tray seams to work fine.
        • Haroldbfix
          • 212
          Its been some time since the original post. What did you come up with on this problem. I have a similar issue.
