C224e external memory
    • 14739
    I have a C224e in the shop and it will not allow me to use an external memory. It is a thumb drive that works on all the other machines that I service.
    I have checked Admin-system settings-user box settings-external memory function settings to make sure all the settings are on. I also did a data clear so now I have the movie data error and the external memory still doesn't work. Is there a setting to allow external memory usage?
    Any info is appreciated.
    Update!!! We got this machine from a wholesaler and the USB cables on the right side where connected to the wrong ports. Thanks for checking this out.
  • minimerlin
    • 851
    Re: C224e external memory
    Where are you trying to plug the drive in? Is the USB extension cable correctly connected at the RH side ?
    Please do not PM me without asking first.
