konica minolta buzhub c224e malfunction c0211
  • brent
    • Nov 2008
    • 1214
    so I know this code is for the manual bypass. and they never even use the bypass. but it shut down the copier.. I have made it so it runs but I need to get the code sorted out.. when I open the door and manually depress the lift gate and cam it all seems to be good. when I reset and turn off and on the sub power then power down and up.. it makes a noise like no other.. any thoughts or tips on this for me? thanks
    brent
  • allan
    RTFM!!
    • 5462
    Re: konica minolta buzhub c224e malfunction c0211
    If they don't use it at all. You can disable it.
    I think its
    Service mode -> System1 -> Problem unit isolation set, then look for manual tray.
    Not a real fix.
    Could be a silly little problem.
    Whatever
    • brent
      • Nov 2008
      • 1214
      I just may have to disable it... then they would want to use it.. and you are right its probly a simple little sensor or something
      just trying to see if someone ran across this scenario thank you
      brent
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Check the screws on the bypass unit. There is one that if you use a long screw instead of the short one it interferes with either the clutch or a gear causing a noise and error code.
        • brent
          • Nov 2008
          • 1214
          I am headed down to look at this beast again tomorrow.. I may have to disable it if I can't figure it out
          I was hoping there was a update on this.. or a tech advice but I have not been able to find it
          thanks brent
