c350 print connect
  • james
    • Jul 2008
    • 21
    c350 print connect
    I am trying to set up a c350 to print for the first time. I loaded the driver, but unlike 70 series the port must not be 10001. I am having alot of trouble with this one. Can anyone walk me through each step?
  • knightfall
    • Jul 2006
    • 633
    What type of network and OS are you using a printserver or direct print? what print controller?
    Get your facts first, and then you can distort them as much as you please.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      If you have the Fiery Controller (IC-402 I think) then the port must be configured properly based on which queue you want to print to.
      • james
        • Jul 2008
        • 21
        Direst print. I think I solved the problem. I checked LPR and entered print. It printed a test page. Still working on scan. Thanks for your help. I've worked on konica in Orlando since the 1803's. Not great with computers, getting better all the time.
        • cobiray
          • Mar 2008
          • 1199
          Direct, Print and Hold are the queue names that can be used. We generally use the Direct queue when setting them up.
