bizhub 250
  • Gab
    • Aug 2015
    • 671
    bizhub 250
    touch panel didn't work (keys worked) . two plastics that screws screwed were broken . I qlued the plastics also replaced touch panel (because it fell down and broken) . But when i use it have smae problem . Is there anything i must take care?
  • allan
    RTFM!!
    • 5462
    Re: bizhub 250
    Change the panel that is the only fix i know.
    Whatever
    • Hansoon
      • Sep 2007
      • 3389
      Re: bizhub 250
      If you replaced the touch panel with a new one (used will NOT work well, cause having the same inherited problem from the old series) and still not working, than I would clean the rim where the touch panel sits on. Often crud is coming between the touch panel and the underside of the control panel cut out. Did you do the calibration BTW?
      Hans
      • Gab
        • Aug 2015
        • 671
        Re: bizhub 250
        Hans
        How can i do calibration BTW ? Only keys are working not touch panel.
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: bizhub 250
          Did you install the touch panel upside down like I did once?...doh!
          • Gab
            • Aug 2015
            • 671
            Re: bizhub 250
            I installed it right.
              • 14812
              Re: bizhub 250
              Then try another touch screen. It could be defective.
