biz 420 error 3201.
  • Gab
    • Aug 2015
    • 666
    biz 420 error 3201.
    I checked gears of fusing are working ok. What else can it be?
  • allan
    RTFM!!
    • 5459
    Re: biz 420 error 3201.
    Can you rotate the fuser by hand if its turning stiff there could be a problem with the bearings.
    If all seems loose enough and change the motor.
    Whatever
    • ranjitkr16
      • Jul 2014
      • 23
      plz check the fusing motor by load check ,if its working check the pully gear which give drive to fusing unit
