Bizhub C224e ghost image
  • photocopier.technician
    • 27
    [Misc] Bizhub C224e ghost image
    Hi
    I am having a problem with a Bizhub C224e. When printing there is a part of the print that repeats itself on the page. As per experience i thought it was the fusing unit but when i stopped the print before it gets into the fusing unit the problem is already there and also the fusing unit rollers are clean. So its not the fusing unit.
    Then i checked the drum units all of them seem ok. Even tried to swap cyan with magenta but still same problem. When i removed the transfer belt just after a copy i can see the repeated image on the transfer belt.
    Cleaned the lasers and the drum corona
    No error codes or warnings
    I attached a sample for better understanding the problem.
    Please give me your opinion
  • copydawg99
    Re: Bizhub C224e ghost image
    Bumping this
    Also have the exact same problem on a new c224e, 19000 prints in, already changed:
    DRUM
    DEV
    OEM TONER
    Checked xfer belt, and fuser all look ok
    • splblazer91
      • Jul 2014
      • 204
      Not cleaning the previous image off the xfer belt? Ive had that happen on a few new machines. Tried adjusting to put more pressure on xfer cleaning blade but ended up having to replace Xfer Assy.
      • habik
        • 2013
        Are the Drum Erase LED's working / dirty ?
        Try Stabilisation and Backgroubnd reset and Gradation adjust .
        Have you tried playing with the 1st and 2nd transfer?
        Do a listoutput print out and try some adjustments.
        Firmwares HERE
        • CPI
          • May 2016
          • 8
          Plain paper or thick? you can up fuser temp if it's ghosting from fuser. Or set as thick paper.
          • JDR
            • Jan 2015
            • 82
            looks like erase led's lamp doesnt work.
            Did you try monochrome copy ? to find up which color is dead.
            • Tech Helpdesk
              • Jul 2015
              • 112
              It looks like the erase lamps are not turning on.
              Check all the ICP'S on the printer control board (even though the manual does not list erase lamps on the ICP list Konica don't always list all circuits covered.
              Originally posted by photocopier.technician
              Hi
              • B0265
                • Jan 2007
                • 718
                I have heard about a similar problem (on a C454e) but have not been able to reproduce it.
                Is the problem present also if you change the colour of the text from white to black?
                Do you see this happen on all types of paper?
                • hotfuser
                  • 180
                  Hi
                  Are you using OEM toner? i have had this on C220 with exactly the same CQ when using non-OEM ir reproduces the same CQ issues.
                  i used OEM toners and the problem disappeared
                  • TheBlueOrleans
                    • Aug 2012
                    • 232
                    Any comments on whether the original (background image with white text)could possibly be causing this?
                    Genuinely interested.
                    Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
                    • francisco
                      • Nov 2009
                      • 168
                      I have a similar problema whith a ricoh MPC 5000
                      • DigiMan
                        • Jan 2013
                        • 262
                        Had this on a couple of C451's,main drive assy on both of them solved it.
                        I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
                        • habik
                          • 2013
                          Did you find anything odd on the drive ass'y?
                          Sent from my iDon't believe in marketing device using Tapatalk
                          Firmwares HERE
                          • DigiMan
                            • Jan 2013
                            • 262
                            Well 4 years have passed but as far as i remember no,didn't find anything while inspecting it.
                            • habik
                              • 2013
                              Thank you!
                              Sent from my GT-I9300 using Tapatalk
                              Firmwares HERE
