Can somebody help with a CF2002 with a 3C50 error
CF2002 with Error 3C50
I don't see that error code in the troubleshooting section of the manual. Usually the codes are Cxxxx (i.e. C0500). Did you mis type the code maybe?the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed. -
8020/CF2002/8031/CF3102��Codes C-3C00 through C-3C40 indicate a corrupt BRU
��Codes C-3C50 through C-3C90 indicates a problem with the PWB-C board or the scanner to
main body cable
lvangsnes
Darren is correct. I have been able to just clear the code and the machine will run fine for several weeks after. My customer doesn't want to buy a C board...they are kind of pricey for an older machine.Comment
Add an electrolysis capacitor (100 microfarad) to C143 in parallel on the PWB-C .
Solder the capacitor on the existing C143.
Capcitors recommended by KonicaMinolta:
- UVR1C101MDD1TD(Nichicon)
- ECA1CM101(Matsushita electronics)
- RE3-16V101M(Elna)
- 16YK100M(Rubycon)Comment
williama
williama
john123
Image units
Hi, I recently bought a copier cf2002, it was saying to replace image units red and blue, did that and it works but soon after yellow image came up too, replace it and keep saying same msg to install the yellow image?
any help would be much appreciated...
ThnxComment
dfussell
Imagistics Color Copier
C-3c50
The only way for the machine to continue is to open and close the front door and shut machine off then turn back on.
This happens everyday and takes even more effort on a following Monday after a weekend.
Any suggestions would be greatly appreciated.Comment
Did you read all posts?Comment
