Biz C6000...Yellow banding
  • remati
    • 149
    Hello people
    -About the problem "yellow banding" -any new ideia..? or something new..?
    -I still have problems with this topic...
    thanks a lot
  • Mick01
    • Nov 2012
    • 362
    Re: Biz C6000...Yellow banding
    Hi,
    Have you tried the New color developers (DV617)?
    These are effective at minimizing the Developer Memory banding that is evident on this model.
    You need the latest firmware with dip switches set up for the duty cycle.
    Hope this helps
    • remati
      • 149
      Originally posted by Mick01
      Hi,
      Hope this helps
      -----thanks for your reply
      yes I had already tried everything ..new developer..and so on...and still have banding
      thank you
      • Mick01
        • Nov 2012
        • 362
        Can you please outline what you have done so far to try and eliminate this problem?
        "Tried everything" doesn't give people reading your post much to go on to try and assist.
        • LinxTech
          • Jan 2016
          • 19
          Would be great if you could give us picture of the problem.
          I've had some issues with yellow, but I'm not sure if we are talking about the same issue.
