Konica Minolta bizhub c280
  • Ahmed Bushara
    • Mar 2015
    • 26
    hi. every one i have Skew problem i adjusted from service mode but problem is still any help!
    Thanks and best regards
    Ahmed Bushara
    Electronic Engineering technician
    Mobile: +249-999198804 /+249-123198804
  • JDR
    • Jan 2015
    • 82
    Re: Konica Minolta bizhub c280
    do you have any malfunction codes ? like P, L or smth ?
    Do you have skew on CMY ?
      • 14812
      Is it skewing off the glass or from the DF or both? If DF only adjust the screw on the right hand hinge. If both, the left front corner of the scanner bed is likely sagging, give it a sharp lift upwards at that corner.
      Hope this helps.
      • wseyller
        • Sep 2012
        • 1129
        Happen with internal test prints? Happen with all trays?
        Sent from my XT1254 using Tapatalk
        • iceman490
          • May 2014
          • 46
          Could be getting caught by the guide by the registration roller.
          Sent from my SM-G920V using Tapatalk
          • Hansoon
            • Sep 2007
            • 3389
            I have pain in my leg. What could it be?
            Hans
            • Ahmed Bushara
              • Mar 2015
              • 26
              skew came when printing test pattern and PC printing.
              Ahmed Bushara
              • mo0651
                • 1054
                Did you check the paper guides in TRAYS? Transport guides break and pop out. Now that we have done all the work, what have you done?
                • wseyller
                  • Sep 2012
                  • 1129
                  Also check if image is skewed on transfer belt and/or drums. Because you need to determine if it is paper feed issue or skew in image process.
                  • cristachecri
                    • Mar 2015
                    • 31
                    Re: Konica Minolta bizhub c280 - copy / print jammed ONLY in color mode
                    Hello everyone .
                    I have a Bizhub c280 machine and has a problem: just in COLOR copy / print mode the paper jams. Specifically as in BLACK copy / print mode everything is fine. It is a frustrating flaw and I can not find the solution. Why is this problem only in COLOR mode ? I'm waiting for your answer or a repair method with great interest . Thank you
