Di5510 j17-10
  • konisolver
    System Engineer
    • Oct 2007
    • 137
    Di5510 j17-10
    I have a J17-10 that as soon as I turn the copier on the jam code appears. There is no paper anywhere (adu/conveyance/exit) In service mode 47 code 23-3 (PS44 shows a constant H) I swap the upper and lower photosensors with the same result. I also replaced the ADU driver board - any suggestions?
  • Scott_Lewis
    • Mar 2007
    • 519
    Have you checked for continuity from the sensor connector to the ADU board?
    • konisolver
      System Engineer
      • Oct 2007
      • 137
      Short on the wire.
      • DUKEY
        • Sep 2008
        • 56
        this machine dumps toner and developer!!! not all but alot of them.. u must take adu apart and clean the sensors which are giving u the high, i've never seen a short or pinched wire before, but there is always a first!! was the machines adu serviced while on? make sure dip sw 3-1 not on! its the latch for lock ups
