Clutch
  • paulrid
    • Nov 2011
    • 206
    Clutch
    Hi all,
    just a quick question, I know many of you have talked about the clutches in paper pickups as I've read loads of threads which have help me massively but I'm not sure which clutch (or is it a case of all them) need changing.
    if you see the attached is it the two smaller ones no 11 or the bigger no 25?
    many thanks Paul.
  • suomi
    • Oct 2008
    • 152
    Re: Clutch
    Both.
      • 14812
      Re: Clutch
      All of the clutches can be cleaned. They get rusty inside and a wipe with some alcohol fixes them. Just gently remove the star ring with a small screwdriver. It is quite easy.
      • paulrid
        • Nov 2011
        • 206
        Re: Clutch
        I shall give cleaning them ago.
        thanks Paul.
          • 14812
          Re: Clutch
          thanks Paul.
          Cleaning almost always fixes them, but it is always a good idea to have new ones with you in case cleaning doesn't work.
          • paulrid
            • Nov 2011
            • 206
            Re: Clutch
            What's your preferred alcohol? Mines red wine but I think in this case it would be methylated spirits
            also do you take them off and soak them for a certain amount of time or just get in there and spray them and get a brush on them?
            many thanks Paul.
            • Zeldaman
              • Mar 2011
              • 946
              Re: Clutch
              Hi there!
              We use either "tuner-spray" or brake-cleaning-spray.
              Greetings...
              • allan
                RTFM!!
                • 5462
                Re: Clutch
                Jip spray contact cleaner works well.
                Whatever
                  • 14812
                  Re: Clutch
                  many thanks Paul.
                  Whisky is the alcohol I use to forget my day, but I use 99% isopropyl for cleaning clutches. I don't soak them, I gently remove the star ring and wipe the contact surfaces with the alcohol.
                  • habik
                    • 2013
                    Re: Clutch
                    Iso-propyl alcohol 99.97%
                    Sent from my iDon't believe in marketing device using Tapatalk
                    Firmwares HERE
                    • Don N.
                      • Nov 2011
                      • 409
                      Re: Clutch
                      We spray the #25 clutch with CRC electronics cleaner (Walmart auto Dept $4.77)
                      We take the one-way bearings #11 off of the shaft & flush with 90% isopropyl alcohol, and if there is a shine on the shaft, we burnish the shaft with scotch brite or super fine sandpaper like 400 grit. Replace tires about every 100k.
