Bizuhb C308 - Compact PDF Scan Issue
  • Wayno
    • Apr 2016
    • 4
    [Misc] Bizuhb C308 - Compact PDF Scan Issue
    Hi Everyone,
    Has anyone here come across a poor quality scanning issue when using compact PDF on the Bizhub C308?
    I have tried a combination of setting changes and loaded the latest firmware, no luck.
    Images are faint and sometimes unreadable and distorted.
    Hopefully someone can shed some light.
    Thank you in advance.
  • allan
    RTFM!!
    • 5462
    Re: Bizuhb C308 - Compact PDF Scan Issue
    The other formats ok??
    Whatever
    • DigiMan
      • Jan 2013
      • 262
      Interesting.
      Didnt find anything relevant at KM.
      I presume no problems at copying etc?
      I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
      • mo0651
        • 1054
        The firmware update also includes some dipswitch changes. did you set those??
        • allan
          RTFM!!
          • 5462
          Firmware release notes. Who reads those
          Post a sample
          Whatever
          • Wayno
            • Apr 2016
            • 4
            other formats are fine, only when using compact PDF.
            unfortunately the customer needs to use compact PDF due to file restrictions on email.
            • Wayno
              • Apr 2016
              • 4
              Originally posted by DigiMan
              Interesting.
              copying is fine. only when scanning using compact pdf.
              • Wayno
                • Apr 2016
                • 4
                please post.... when i received the firmware no one bundled the release notes for me.
                • DigiMan
                  • Jan 2013
                  • 262
                  The only thing "somewhat" related to your problem i found
                  C-E301 and others occur if documents of two pages or more are copied/scanned/received when the file type of an image is set to "compact PDF". [ERBJSL1500853057
                  but since you say your copy is ok im not sure,you dont get any error codes right?
                  Checked the history of error codes?
                  Also post a sample pic if you could please.
                  • CopyJunkie
                    • Oct 2012
                    • 28
                    I want to say I ran into something exactly like this on a 4e series machine. We ended up increasing the resolution (I want to say 400dpi) and the quality was acceptable and the file size didn't increase too much. I'm just taking a guess here but I think it has to do with the Compression/Decompression process and it's interpreting the light spots as white.
                    NOTES ON HOW TO USE THE FAX MACHINE.
                    1. Get into your DeLorean (or your TARDIS) and go back to 1990.
                    2. Place papers in the machine - Face Down.
                    3. DO NOT dial 9
                    4.
                    Rejoin the rest of modern civilization.
