ERROR CODE C2701
  • husamelamin
    • Jul 2025
    [Error Code] ERROR CODE C2701
    Dears.....
    I bought new konica minlta c1060l and i shipped it from dubai and due to electrical problem i lost the pcb so i had to send it back again and replace it with new one,i bought voltage regulator to solve the problem and i grounded the body to the earth bar..suddenly this code error had shown up (error code c2701).and the machine refuses to work.
    I will be greatful if some1 could help out how to solve this issue,if steps will be given it would be perfect.
    Many thanks and best regards.
    Sam
  • kylebishop
    • Dec 2015
    • 11
    Re: ERROR CODE C2701
    I found this. Not sure if this helps. Different machine but same code.
    http://www.copytechnet.com/forums/ko...-c-2701-a.html
    • TheBlueOrleans
      • Aug 2012
      • 232
      Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
