Wavy Edge C5501
  • WoodyC
    • Sep 2010
    • 21
    Wavy Edge C5501
    Our C5501 has developed a strange kink/wave on the trail edge of a printed sheet. This is a 1200 sheet SRA3 100gsm job - paper fresh from packet.
    It never used to do it and our engineer initially blamed the paper - so we changed papers. The problem didn't go away. It also seems to get worse as the run progresses.
    I tried a short run with finisher detached and it seemed to be OK (I'll do a fuller test when I get a chance). The de-curl rollers were changed a little whoile ago so he's ruled that out.
    Does anyone have any suggestions? With the finisher door open the punch unit (not being used for this) seems to rock quite a lot but I don't know if that's normal. Any ideas appreciated as I'll be getting them back in shortly.
    Michael
  • Max
    • Oct 2011
    • 561
    Re: Wavy Edge C5501
    Does it do it when you turn the paper around? (face down/up)
    • WoodyC
      • Sep 2010
      • 21
      Re: Wavy Edge C5501
      Yes it does it either way. Sometimes it just seems to curl but other times it's almost like a fold.
      • tech51
        • 846
        Re: Wavy Edge C5501
        That looks like wear on the fuser exit guide. I can't remember it's correct name but it's the sprung loaded guide by the lower roller on the exit side of the fuser.
        I've changed a few of these for this problem....
