Why if I use only black color, the transfer belt does not get dirty and print correctly.
If I stamp with the colors, it dirty and leave the lines on the sheets?
..because it is worn out and you need to replace it..see a previous post also advising you to replace it!
I have the same problem with c360. In my case halftone problem was in magenta and black. Replaced transfer belt and transfer roller had no effect. After initialize + image stabilization (twice) and gradation adjust problem solved, but IDC (in level history 2) have different value. If initialize and stabilize not help, I think the problem can by in IDC.
