Firmware updated, am I looking at MFPB and/or SSD, as per manual, or does someone has the miracle cure !!!
C3350_ 4901 code
Tags: None
Re: C3350_ 4901 code
What you have are two different problems the code that starts with 33 temp control code and the code that starts with 49 fan error. MFP problems you could get error codes that will not go away after reset holding down the utility key when main power is turned on until KM screen shows wait until reset key appears press reboot machine this is only for the KMBS type machines. Also if this is a KM machine you can not replace the NVRAM and the MFP at the same time even if the MFP is bad the boot data will not backup. If any MFP first with Firm ware. If the machine is rebooting by it self NVRAM only.
