BH-423 with FS-527, paper curling
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    #16
    Re: BH-423 with FS-527, paper curling
    Did you try to lower Fusing temperature in order to reduce curling of the paper?
    Just FYI they(KM) called this function High Humidity PPM Adjustment in 8-series manual and Fusing PPM control in i-series
    Yeah, back when we were having some machines with the issue, we tried decreasing and increasing the fuser temp without any change. I think for the most part, the places that were having the issue had cheap paper. We haven't really had many issues with this in the last couple years so maybe the customers listened and got better paper.
    Yeah, I saw that KM changed the name in the newer machines because I wanted to find out if it was a feature on more than just the 423 series. Now we just need somebody to start using cheap paper or run their machine in a humid environment to find out if the setting works.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
