error c2152 on ineo 454 e after changing the transfer belt !
  • jakani
    • Dec 2014
    • 147
    Hi ,
    i have got this error after i changed the transfer belt with a new one ,
    i installed the old one back and after opening and closing the front door the error disappears ,
    i noticed that the old transfer belt is different from the new one as you can see in the images
    the old one :
    the new one :
    i thought of removing those clutches of the old transfer belt and put them in the new one but i want to ask for an advice first or any suggestions about this problem
    thank you very much
  • delboy10
    • Jun 2010
    • 43
    Re: error c2152 on ineo 454 e after changing the transfer belt !
    Originally posted by jakani
    Hi ,
    the old one :
    [ATTACH=CONFIG]32916[/ATTACH] [ATTACH=CONFIG]32915[/ATTACH]
    the new one :
    [ATTACH=CONFIG]32917[/ATTACH][ATTACH=CONFIG]32918[/ATTACH]
    thank you very much
    Your new ITB is for the black and white model part #A61DR70000 ( Bizhub 454e).
    You have to order a proper ITB for the color model Part # A161R71300 (Bizhub C454e).
    If you stuck you can try to transfer the belt over to the old one. It is not too bad to transfer, you can remove the pressure spring so the frame assembly can bent a bit then you can remove the belt.
    delboy
    • John Kaufmann
      • Sep 2013
      • 114
      General, dumb question: Why does a B&W unit need/use a transfer belt?
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        The Color models came out first...and rather than redesign a new engine they just pulled out the color drums and devs.
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • jakani
          • Dec 2014
          • 147
          delboy
          thank you very much for your advice and the part numbers
          and i think i'm gonna try to transfer the belt over to the old one that the only solution i have for the moment
          • allan
            RTFM!!
            • 5462
            The transfer belt also protects the drum and even the dev will last longer. Its a great thing.
            Whatever
            • John Kaufmann
              • Sep 2013
              • 114
              That's interesting. I can see why it protects the drum (though, at the cost of a belt, the merits of that trade-off are not clear to me), but how does the dev last longer?
              • allan
                RTFM!!
                • 5462
                Less paper dust fiber, hair... that goes in there.
                So not really the dev but more the entire unit.
                Take a C360 drum and dev tank compared to a B363 drum and tank.
                The C360 K drum can do up to 350K if the charge is kept clean.
                The B363 drum will do about 250K max.
                Whatever
