Km bizhub 451 printing problem on banner.
  • smiley
    • Aug 2008
    • 615
    Good day guys itry to print on banner but machine pop this error20160606_105822.jpg620160606_105822.jpg anyone expirience this thanks in advance
    there is no glory without sacrifice
  • emujo
    • Jun 2009
    • 3009
    Re: Km bizhub 451 printing problem on banner.
    Not sure if this will help..
    1. No banner printing if FS 517/608 is mounted
    2. No banner printing if "vendor mode" is enabled
    3. Before you send a banner, you must turn banner printing on through the control panel. After you must turn banner print off or all other print jobs will be deleted. Emujo
    BTW posting the same picture upside down twice, really doesn't help.
    • smiley
      • Aug 2008
      • 615
      Thank you for the response sir. Im sori i attached the image the wrong position. What do you mean a vendor mode? This machine doesnot have a finisher.
      • sidney
        • Apr 2016
        • 4
        Banner print is only thick 3
        Enviado de meu SM-G531H usando Tapatalk
        • emujo
          • Jun 2009
          • 3009
          Vendor mode means that you have told the MFP that there is some kind of authentication device attached..Key counters and and 3rd party copy track devices fall into this category. If anything was ever installed, simply turning off vendor mode may not correct the problem as some settings have to be manually reset. BTW, you should not have to select thick modes as when you send a banner the print driver auto sets up for the required modes. Emujo
          • smiley
            • Aug 2008
            • 615
            Thanks for the reply sir. How can i turn off the vendo mode. this machine has a finisher before and been removed. Is there a anything to do after removing the finisher to activate the banner printing?
