C280 blurry Lines running across the print on heavy card stick
  • ywajihi
    • May 2025
    Whenever i print on heavy card stock... 200gsm plus... using thick 3 or 4 setting, i get blurry lines appearing on the print throughout. This wasnt there when the printer was new. What could have changed since... printer is only 3 months old.
    Meant "STOCK" in the title.
  • granata
    • Jan 2012
    • 32
    Re: C280 blurry Lines running across the print on heavy card stick
    hi,change itb unit
    • brianho80
      • Sep 2009
      • 198
      Is the line repeat in the same position?
      You may perform some checking as below steps:
      1, drum
      2, ibt belt
      3, fuser roller
      4, or clean up laser unit
