I Have a Konica Minolta Bizhub C652DS and the machine needs a yellow imaging unit replaced, I decided to experiment with replacing the drum chip, so I removed the screws in the front of the drum and removed the plate where the wires sit that meet contact, there is meant to be a small board there for me to unplug and repugnant a new one in order for the drum to reset once I've placed it back in the machine. But there's no board the it's just a wire that runs straight from the toner sensor that sits on the dev that goes straight to male terminal that sits on the drum when you b slide in the machine. Any idea on how to reset these kind of drums???
Konica Minolta C652DS Drum Chip
Re: Konica Minolta C652DS Drum Chip
I'm not following sorry. There's something obviously in the drum that the machine picks up since I replaced a drum with a half used one it know there's a half used one in the machine. Theno when I place the used one back inside the machine it knows it's used it says replace Yellow IU I'm trying to figure out how to reset the machine displaying replace Yellow IUComment
Initially the machine does not need the chip the count is held by the machine, then you can put any used unit without a chip in there and the machine would not be able to tel the difference. If the preset count on the machine runs out it needs a new IU out of a box to reset the count. From there the count is held by the chip on the replacement unit.
So if you move a used IU from one machine to the other it reads the count from the chip.WhateverComment
