C550 Cyan skewing
  • Mattb17
    • Aug 2025
    C550 Cyan skewing
    Cyan skew cannot rectify tried cleaning iD sensors skew adjust and most other adjustments managed to reduce the skew but not completely gone. Any ideas would be greatly appreciated
  • techmann
    • May 2016
    • 41
    Re: C550 Cyan skewing
    You could have something as simple as the Magenta drum needs replaced, or a dirty registration sensor. How does you consumables look? It may also be a bad PH, but I believe there is a physical adjustment you may want to try before ordering a new one.
    • Mattb17
      Hi thanks for the reply
      I have attached a print out of the consumables list I have cleaned the sensors.
