Konica Minolta bizhub C35 Scanner Belt Replacement.
  • Nila
    • Aug 2025
    [Misc] Konica Minolta bizhub C35 Scanner Belt Replacement.
  • copyrooks
    • Oct 2013
    • 210
    Re: Konica Minolta bizhub C35 Scanner Belt Replacement.
    Try this bulletin
    • TheBlueOrleans
      • Aug 2012
      • 232
      Remove ADF (4 screws, one ferrite core, disconnect one connector)
      Remove top of scanner unit (with platen glass) (10 screws)
      Remove screw from shaft at front right corner of scanner unit, where the belt attaches on the right.
      (this will allow access to the screw mounting the scanner belt in place)
      Lift the image reading unit from the rear shaft (it will lift freely), swing it over toward the front of the machine.
      Pay attention to how the belt is routed on the gears beneath the image reading unit. (I personally prefer to take a picture with my phone, but you do whatever works best for you.)
      Remove screw from far right end of scanner belt, lift belt off of plastic post to remove the belt itself.
      Repeat for left side of belt.
      Install new new scanner belt with the spring on the left post, reinstall screw, routed around the gears exactly as the old one, slip eyelet of new belt over post on right side of scanner unit, reinstall screw.
      Return image reading unit to its proper horizontal position, manipulate it back and forth to see if the belt is staying on the gears. If so, move on to reinstalling scanner unit top (with platen glass) and ADF. If not, recheck the mounting position of the belt on the gears until you have it right.
      Overly verbose, probably oversimplified, bordering on insulting (if so, I apologize), but this is the exact method I've used a dozen times or more.
      Just because I hate the C35 as much as, if not more so, than it hates me, doesn't mean I don't know it.
      Don't get me started on "Install Toner Cartridge Y And Close Door".
      Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
      • JR2ALTA
        • Feb 2010
        • 2033
        First time I did it was trying to route the belt from the wrong side first. I couldn't understand why it would matter, but once I flipped it around it went in easy.
        • habik
          • 2013
          Just follow your instinct!
          Bit of a logic and you done in 2 minutes.
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • allan
            RTFM!!
            • 5462
            Busy making a CNC machine from 2 C360 scanner beds. By accident i let the scanner cables uncoil. Not quite 2 minuets but logic helps a lot.
            Now i have the martial art of the octopus down.
            Whatever
