FS519 C-1183
  • xdelios
    • Apr 2016
    • 27
    [Error Code] FS519 C-1183
    Hello,
    I am experiencing a problem with a FS519 finisher on KM C253
    This error code appeared in the past once again, I then searched the forums and found some reasons this could happening.
    Honestly all I did is unscrew some things and re-screw them and it worked.
    I put it back on yesterday.
    Today I got the same problem.
    The thing is it happened when I was about to get a page printed on the lower tray of the finisher. This was the case the first I got the error as well.
    So the finisher starts moving up and it gets to the point it should and then stucks.
    I know the lift motor isnt the problem cause I used it on another FS519 and it worked just fine.
    I re-inserted the trays in case something was wrong there but still nothing.
    Any ideas?
    Regards,
    George
  • habik
    • 2013
    Re: FS519 C-1183
    Have you tried screwing in top tray properly or in different slot?!
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • xdelios
      • Apr 2016
      • 27
      Re: FS519 C-1183
      Hello,
      The plastic holders tha came with the finisher fit exactly is a specific spot from the right side. So changing the place of it aint an option.
