c3350 showing toner empty
  • Brett GS
    • Jun 2013
    • 154
    Hi all
    I got a new C3350 that gave a c2557.
    The black image unit has been replaced with a brand new one.The toner is still full and the machine see's that there is a toner but shows that its empty,so a brand new black toner was also replaced but still gives the same issue (empty toner). Machine says replenishing toner but then
    Says replace toner.
    Any ideas??
    Im going there tomorow to see if i am missing somthing.
    Brett
  • TheBlueOrleans
    • Aug 2012
    • 232
    Re: c3350 showing toner empty
    If this is anything like the C35 "insert toner cartridge (whichever color) and close all doors" problem, it is likely a sensor connector unplugged in the toner hopper assembly.
    Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
    • Millennium
      • 30
      Also make sure the toner motors are working. If it doesn't feed to toner into the IU you will get similar errors.
      Sent from my Nexus 6 using Tapatalk
      • minoltaed
        • Aug 2009
        • 45
        Originally posted by Brett GS
        Hi all
        Says replace toner.
        Any ideas??
        Brett
        Did you find a fix for this?
        • allan
          RTFM!!
          • 5462
          Curios about the toner supply on these.
          We have only 2 of these machines they don't seem to fit in the market here.
          I don't even have a manual for them but if the toner supply is anything like the C35 the toner supply is driven by clutches from the same motor.
          Could it be a bad clutch?
          Whatever
          • habik
            • 2013
            Think there is a DIPsw 5 that can reset the toner recovery. If its bad contact, you may need to investigate as mentioned above.
            Firmwares HERE
            • rrrohan
              • Sep 2011
              • 1977
              Id replace the IU
              Sent from my SM-G900I using Tapatalk
              • CraigW
                • Dec 2010
                • 417
                FYI
                Got a call on a C3350 at about 15k total, Ran the K toner empty, and had no new spare on hand. So, a used K toner (quite heavy still) from another currently idle C3350 was installed and the bars stayed all white and the "replenish toner" message would not clear. Did toner auto supply with no luck. Toner add motors only ran in load check mode.
                Boss located a new spare and it allowed the machine to come to ready, and K toner level to 100%.
                We are not sure if dipswitch 5 would have resolved this or not....??? If we get another one we are going to try it out and see.
                • Brett GS
                  • Jun 2013
                  • 154
                  Originally posted by CraigW
                  FYI
                  Turned out being two faulty toners on my machine,new k toner replaced by myself and then all started working fine and showing 100% toner.
