Konica c6500 black developer prints weak
  • impimp329
    • Aug 2010
    • 55
    Hi all, I have just changes the developer twice on a c6500 and went thru all the settings, and it still prints grey on a sky shot. I have changed the drum and corona and still, nothing. I have also increased the developer and toner to +5 and that had little affect.
    Please, anyone has an idea, maybe I missed something. Machine gives no codes and I get no errors when I go into service mode.
  • tulintron
    • Jul 2014
    • 668
    Re: Konica c6500 black developer prints weak
    Run Recall Standard Date Adjustment Process and choose the Factory Default option.
    Note the black back and run the developer replacement procedure.
    • Smircea
      • 15
      Few things you can try w/o changing to many parts is to change parts from yellow to black. When you remove your belt and drums you should see a long board with leds... try to xchange black and yellow. Also there could be a problem with laser unit.
      Try to print a pattern test on black at 125% and 255% and post those ... maybe i can tell you if there is the laser unit since i had the same problem and after i changed the laser unit it was fine for me.
      Best of luck!
