C554e FD00 errors
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    C554e FD00 errors
    Got a new machine throwing these errors every morning, I note that its relating to an ASIC on the mfp board involved with scanning among other things. (mfp board is new, made no difference)
    What I stumbled across today is that one of the CCD clamp values is off the scale & absolutely stupid.
    The machine is locking up very intermittently when making copies, can print all day long without a hitch.
    Going to try a CCD unit on monday.
    There are no S- code warnings or I would of looked here first and saved my self the effort of changing the mfp board!
    Anyone had this ?
    Not only FD00 errors it has had just as many slider over run errors too.
  • Gift
    • Mar 2011
    • 2458
    Re: C554e FD00 errors
    all values are around ~1000 at your pic, shure this is stupid compared to other machines?
    Looks a bit odd at first since the numbers are baked together^^
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      You're right. i didnt count the digits properly. I thought the last one was 9999
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        I think I'll try the CCD anyway, I've pretty much got nothing else left to change.
        inside scanner: pwb-id, stepper motor and home position PS replaced
        inside machine: mfp, ram, DSIPB, interconnecting flat cable replaced
        nothing has made any difference,
        Machine is likely to be scrapped and the customer given another new one.
        • habik
          • 2013
          Not sure if it is related but seen a post somewhere about pinched cable.
          Firmwares HERE
