BizHub C250 error code C-D36F
  • bb4u929
    • 15
    I'm just wondering what the error code C-D36F for BizHub C250, and what's the resolution for the issue. I can't find it on the Service Manual or online.
    Thank you very much!
  • allan
    RTFM!!
    • 5462
    Re: BizHub C250 error code C-D36F
    The manual does point to the NVRAM but no detail only shows C-D3XX.
    Guess the NVRAM is faulty or recovery is needed.
    Whatever
    • bb4u929
      • 15
      This error become intermittent problem, sometime the copier works fine, but most of the time I getting the same error code.
      How can I check to see if the NVRAM is faulty? I ran the memory test on the copier and it passed the test.
      How to do a NVRAM recovery?
      Does anybody have the firmware update for my copier?
      Does anyone have access to order the replacement NVRAM(I'll provide the serial number of the copier for the order)?
      ROM Version
      MFP Controller BOOT Program 4038-1E00-G00-03-000(00)
      MFP Controller SubSet Program 4038-1F00-G00-13-000(00)
      MFP Controller 4038-0100-G00-75-000(00)
      Operation PANEL Message Data 4038-8100-G00-65-000(00)
      FAX Board Controller1
      FAX Board Controller2
      IR 4038-0023-G00-07-000
      PRT 4038-0050-G00-10-000
      LPH
      ADF 4582-24G0-08-00
      Finisher
      System Controller 4038-1000-G00-75-000(00)
      Printer Controller 4038-3000-G00-29-000(00)
      Printer Controller-Font 4038-3F00-G00-07-000(00)
      Printer Controller-Demo Page 4037-3E00-G00-00-000
      MIO 4038-5000-G00-45-000(00)
      PSWC 4038-5100-G00-38-000(00)
      MIB IF 4038-5200-G00-16-000(00)
      IPP IF 4038-5300-G00-03-000(00)
      External Controller IF
      TCP/Socket 4038-6300-G00-06-000(00)
      Open API 4038-7000-G00-86-000(00)
      Operation PANEL 4038-8000-G00-04-000(00)
      CSRC 4038-8300-G00-03-000(00)
      PIC 4038-8200-G00-16-000
      I appreciate all your help.
