Copy problem with Konica C6501
  • sadanand
    • 62
    Dear sir I am getting magenta banding on the end of every copy .Kindly help me to solve this problem Thanks in advance
  • Shano74
    • Oct 2009
    • 25
    Re: Copy problem with Konica C6501
    what did you do?
    • sadanand
      • 62
      Originally posted by Shano74
      what did you do?
      Ths is 12 x 18 print I tried with replacing drum unit ,DP unit and laser but oops nothing changed
      • Shano74
        • Oct 2009
        • 25
        Ok,i will try to help,i dont know your experience level on this printer
        i no longer work on Printing equipment,but work on Medical devices
        my heart is still with printing equipment tho.
        the first thing i would do is,clean all your sensors and gice the drum cavity and belt assembly good clean.
        check belt assembly especially,make sure the ibt rollers is properly engaged and moving correctly.
        next thing i would do is do all the adjustments regarding colour adjustments.
        stop replacing and stop guessing.
        check basic printing,check if this is only occuring on heavy stock(paper)
        i havent worked on Printers fir 3years,but im sure with my experience we can fix this.
        also ask the customer questions relating issue,when did this start?
        If what I mentioned ,dont help,let me know and we can move to next step.
        • Shano74
          • Oct 2009
          • 25
          • sadanand
            • 62
            Thanks Sir Very much I am a tech. have done all above things cleaned IBT unit as well as Image unit awaiting for your reply
            • Shano74
              • Oct 2009
              • 25
              okay,is the band at the lead edge or trail edge? What is the size in millimetres?
              • sadanand
                • 62
                Banding is at trail edge and also magenta sharpness is not in the copy it is coming as de focused band size is 105mm on trailing side
                • Shano74
                  • Oct 2009
                  • 25
                  Lets try and eliminate,you already swapped drum and laser units,lets swap the cyan and magenta dev units,tape the toner entry part of the assembly,so no toner will enter the unit,make one print and observe.
                  • sadanand
                    • 62
                    yes same problem only magenta is now converted in cyan
                    • Shano74
                      • Oct 2009
                      • 25
                      Ok,so then swap the original dev units back,in the transfer assembly,swap the cyan and magenta transfer rollers around and test
                      • sadanand
                        • 62
                        Tried by replacing transfer roller cyan to magenta but same problem so the problem is not with transfer roller any other suggestions sir
                        • Shano74
                          • Oct 2009
                          • 25
                          Ok,do you have more samples,does it happens on copying as well?does the size of the band stay the same? Is the band to the edge of the page? Did you swap around charge units?
                          can you make a video clip and share? Dont worry we will fix this!
                          • sadanand
                            • 62
                            yrs it happens with copying also size of trail edge band is fixed 105 mmIMG_20160825_123856.jpg
                            • Shano74
                              • Oct 2009
                              • 25
                              yrs it happens with copying also size of trail edge band is fixed 105 mm[ATTACH=CONFIG]33958[/ATTACH]
                              What controller you printing from? Honestly looking at that print it tells me its either your controller or file issue,what you using to create files? I think this is not engine related,this is software related,that band is to perfect.
                              are you sure when you do copy on the glass,that issue happens?
