Konica Minolta C353 Error C2557
  • mearmi
    • Oct 2010
    • 350
    Konica c353 Getting Error C2557
    Replaced the IU-K
    cant see the TCR values in Level History 1
    all values are 0
    Please advise
  • paulrid
    • Nov 2011
    • 206
    Re: Konica Minolta C353 Error C2557
    Try a trouble error reset in tech rep.
    paul.
    • mearmi
      • Oct 2010
      • 350
      paul.
      Have done 2 times
      • Tech Helpdesk
        • Jul 2015
        • 112
        If you have no TCR readings it would suggest the ICP 4 has blown on your MC Board
        Replaced the IU-K
        all values are 0
        Please advise
        • habik
          • 2013
          Try turning the dev gear on all IU's manually and then try Stabiliser and Background reset and then gradations in service mode. If it wont let you stabilise the image, then have a look at the ICP4 as suggested by TechHelpdesk
          Firmwares HERE
            • 14813
            You actually have to run a copy to get a reading in Level History. If you just turn it on and go straight into service mode it will not show any readings.
