Account track printing from Mac OS 10.5?
  • rydmec
    • Aug 2025
  • Specilist KVN
    • Sep 2008
    • 79
    It will be one of two things, either a driver update or an OS update.
    There were MAJOR issues with the account track when 10.5 came out.
    Konica Minolta Business Solutions | Help Desk
    You can find what you need there.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      I had the same problem. When you run the installer it dumps the driver into a number of folders. When I loaded the printer I naturally chose the drive from the KonicaMinolta folder that the installer had created. That was my mistake. You must chose the driver from the library/printers... I can't remember the exact path and I don't have a Mac to look at but if you to where all the other printer files are and choose the driver from there, you will then have the security option available.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • lucky13
        • May 2008
        • 125
        ok i just did this last week on a mac running 10.5.5 .driver on disc is no good go to kmbs website get ver.2.3.0 latest one. delete printer and start fresh with new driver.after installing driver you will see a check box in the installable options area for id-authentication or something like that.if you dont see this option you have wrong driver. now print a document file/print/printer prefrances and in 3rd drop down menu might say copies and pages look about half way down the drop down menu for OUTPUT METHOD and there you will see copy track and authentication name and password fields.good luck
        • 8050
          • 88
          My situation is not with a C451 but with a C452 with a Fiery IC412. Customer would like to use account tracking. I know how to input account password and get it to print. The problem is this only temporary and application specific. In other words let's say they are printing from Adobe Illustrator. You input the account information when you are printing. That's fine when you stay in Illustrator. You have to input the information again when you open up a different application ie: Word or Excel. AND, when you close the application and open it up again, you have to reinput the account password! Unlike PC's where you only have to enter the account password once in the driver Macs don't seem to have that feature unless someone knows another way. Does anyone know anything about this?
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            To my knowledge, there is no way to set defaults like you would on a windows driver.
            I looked around on the knowledgebase, but could not find any reference to work around this, aside from specific instructions on how to input from Illustrator, which you already know.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
            • mrwho
              Major Asshole!
              • 4299
              I'm no Mac wizard (in fact I loathe them) but, like any tech, sometimes I have to work with them.
              To get around that default thing when printing, I usually choose the settings I want to and then I save the preset before giving the "Ok" for printing.
              Another way that might work (although this is just a wild guess) would be to edit the PPD, but I don't really know if that would work.
              Mascan42
              Ibid
              • RRodgers
                • Jun 2009
                • 1947
                Originally posted by rydmec
                I have a Bizhub C451 that I can't print to from a Mac (OS 10.5) while using the account tracking (AT). I've tried using the driver specific to the C451 (ver 4.10) and it gives no option for AT user info in the printer properties. I’ve also tried using the driver for this series printer (ver 1.05). This gave me a check box for ID in the printer properties, but no place that I could see to enter the account info for tracking. I’ve been able to setup Windows based boxes to print just fine using the AT. If I’ve left out any needed info just ask and I’ll do what I can to get it. Any and all help on this matter would be greatly welcomed.
                I just did one of these today. Ya have to open a print job up, and then go into output. It should be in there. I couldn't figure out a way to lock it in (I didn't play with it long) but there is a save info so they don't have to put the code in each time.
                HTH
                • jma676
                  Expert Tech
                  • Mar 2009
                  • 323
                  I have a Bizhub C451 that I can't print to from a Mac (OS 10.5) while using the account tracking.
                  Some Tips from the SSD = (bizhub C550 - ALL ACTIVE SOLUTIONS - 2009)
                  Solution ID TAUS0900142EN*
                  Description
                  Solution
                  Account tracking is supported onMacintosh O/S 10.5.Additionally, the account track selection can be found in the COPIES AND PAGES pull down and then
                  select OUTPUT METHOD.The account track and authentication screen will be present.
                  SPECIAL NOTE : Solution contribution by Mark D'Attilio, Production Print/SSD
                  Other*****
                  Solution ID TAUS0702628EN*
                  DescriptionSolution
                  This is not possible to do with account tracking. In order for this to work, the MFP would have to authenticate with the server.
                  let me know if this really Works*********
                  • Chromatik
                    • Aug 2010
                    • 71
                    What happens with the IC-409?
                    • jma676
                      Expert Tech
                      • Mar 2009
                      • 323
                      consultation with the owner's manual Fiery!
                      • aesthetics1
                        • May 2010
                        • 148
                        I can confirm this.
                        Typically how most Macs are setup by default is to use the user's "Last Used Settings." If you set it up to print using Account Track, exit all running programs, and use your "Last Used Settings" for printing, you shouldn't have any issues with this.
                        Alternatively, depending on the particular driver being used, I have had some success using the settings in CUPS to get the settings to stick.
                        If you're unfamiliar with this method, simply open up the web browser on the machine, type in We'll Have More Soon (or We'll Have More Soon) and play with the settings in there under "Manage Printers." If you are prompted for a username/password, simply use the credentials of the admin account on the Mac.
                        • jma676
                          Expert Tech
                          • Mar 2009
                          • 323
                          Description
                          Solution
                          Other*****
                          DescriptionSolution
                          • Chromatik
                            • Aug 2010
                            • 71
                            oK!!!!
                            • jma676
                              Expert Tech
                              • Mar 2009
                              • 323
                              Some clowns are upset by my answer !!!!!
