Konica Minolta C200 error 3423
  • ivan
    • Feb 2015
    • 12
    [Error Code] Konica Minolta C200 error 3423
    Hello,may i please have solution to error code 3423 on konica minolta C200, I have tried trouble resetting machine but was unsuccesful.
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta C200 error 3423
    If you have another fuser try that.
    Its a low temp condition from the pressure roller.
    Does the fuser heat up at all after a trouble reset?
    If that is the case a sensor could be covered by toner buildup.
    Make sure the connectors are properly seated.
    A lamp could be broken. Use a tester to check for continuity.
    A thermistor could be shot.
    Or the door or latches could be broken.
    Power supply could be bad.
    I would get another fuser somewhere if that does not work i would have a look at the power supply.
    Could even be the AC power supplied to the machine.
    How do you reset the machine?
    How is things there in Mozambique?
    Sure you are working on machines i have work on before from Nelspruit.
    Whatever
    • ivan
      • Feb 2015
      • 12
      Thanks Allan.
      Sorry for the delayed response. It was toner dust I opened the fuser unit and just cleaned it machine works fine now. And yep most machines here come from nelspruit and some come with headaches. Would appreciate it if we could exchange contacts
      Sent from my ONE TOUCH 6012X using Tapatalk
      • allan
        RTFM!!
        • 5462
        Sure no problem i will send you a PM.
        The machines comes from all around moved to Durban now.
        Nice here getting use to coastal living.
        Whatever
