C258 scan delay
    • 14484
    C258 scan delay
    Hey everybody
    I have a customer with a C258 that has an issue when faxing multiple documents.
    She will put the first document in the DF, select the one touch and send, then place the second document in the DF. She will select the one touch, hit Start and there is a noticeable hesitation before the DF will start scanning.(about 5 seconds) I tested it with a 4 series machine we have in the shop and scanning starts immediately when sending the second document. I also tried it with scanning and it does the same thing. This wouldn't normally be a big issue, but it is in a busy law office and they often have many documents to send to many different destinations.
    Tech support suggested initializing fax board and data clear. I did both and no change. He had a C368 at his location and he tested it and it would scan second document as soon as the start button was pressed.
    I installed the extra 2GB memory chip and that didn't help either.
    If anyone has any suggestions it would be appreciated.
  • allan
    RTFM!!
    • 5462
    Re: C258 scan delay
    firmware?
    Whatever
      • 14484
      Re: C258 scan delay
      Originally posted by allan
      firmware?
      I forgot to mention, the tech support guy had me make sure the "power sub CPU" firmware was at G00-10. It is at that level
      • habik
        • 2013
        Re: C258 scan delay
        Is the network speed on auto 10/100/1000MBs!?
        Are the network settings and scan settings identical?
        Try uninstall and re-install the adf with all initial setup settings inc. magnification B side.
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
        • wseyller
          • Sep 2012
          • 1129
          Re: C258 scan delay
          Unless someone else has any other ideas it may be worth doing a full initialization/data clear on this unit and setting it up from scratch and be done with it. Just make sure to write down all the network settings, backup address book, ect.
            • 14484
            Re: C258 scan delay
            As stated in the first post I did a data clear with no change. Thanks for the suggestion.
            • mx6turbo89
              • Oct 2013
              • 154
              Re: C258 scan delay
              Have you tried an HDD format?
                • 14484
                Re: C258 scan delay
                I haven't tried that yet. It is on my list, which only has "format hard drive" on it so far. lol
                • wseyller
                  • Sep 2012
                  • 1129
                  Re: C258 scan delay
                  Oh sorry I read it as you only did fax initialize. I now see you mentioned data clear
                  Sent from my Nexus 6P using Tapatalk
                    • 14484
                    Re: C258 scan delay
                    Update.
                    I went to the customer's on Friday with a diagnostic MFPB supplied by KonMin and the latest firmware, released last Wednesday October 5th. Installed the board and firmware and it fixed the problem. Of course I thought the MFPB caused the issue. So I re-installed the original board and new firmware and when I tested it before leaving it worked properly. Looks like KonMin was aware of the scanning issue and fixed it with firmware.
                    Thanks for all the suggestions.
