Ps8 ps9 color registration sensors replace.
  • stagosal
    • Jul 2025
  • habik
    • 2013
    Re: Ps8 ps9 color registration sensors replace.
    I doubt sensors on its own would be much cheaper.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • mx6turbo89
      • Oct 2013
      • 154
      Unfortunately, those sensors are not available as a separate part from Konica Minolta.
      • Smircea
        • 15
        Unfortunately you cant find only those sensors.
        There is something you could try.
        Clean the transparent plastic cover of every sensor but be careful to not scratch it or break it when u take it down.
        Try to incrase byass fine adj value for M... Try to turn it to 4 and only then do the adjustments.
        This worked twice for me . After 4-5k pages you can change it back to 0 and you will see an improvement to red.
        When your copier isn't printing true red it's not always necessary to replace color reg board. First time i had this problem i changed it and after 2 months the problem was back. That's when i found this lil trick.
        Good luck . I hope this works for you too.
        PS: make sure dev/corona/drums are if not new .. below 50% usage.
