Please help me with error code 3452 from bizhub c352
  • tunduma
    • Jun 2016
    • 5
    i have got a bizhub c352 which shows error code 3452, how can i reset it without using touch screen because a touch screen does not work and am so far from where i can buy new touch screen?
    please help me on how to inter service mode without using touch screen
    also how to reset bizhub c352 without using touch screen
  • allan
    RTFM!!
    • 5462
    Re: Please help me with error code 3452 from bizhub c352
    Does the utility counter button work but you cant touch "trouble reset on the screen"
    Don't know of any other way except for the soft switch setting.
    Whatever
    • tunduma
      • Jun 2016
      • 5
      yes the utility counter button work perfectly but i can't touch because a touch screen stopped working
      • paulrid
        • Nov 2011
        • 206
        As far as I know there is no way to reset without touch screen, you could try and take the touch screen apart and put the touch screen only in the oven. This can bring it back for a while at least.
        Paul.
        • tunduma
          • Jun 2016
          • 5
          Paul.
          is there any way to inter service mode without using touch screen?
          • paulrid
            • Nov 2011
            • 206
            Not that I know off, even if there was you wouldn't be able to do anything without a working screen.
            Paul.
            • tunduma
              • Jun 2016
              • 5
              Paul.
              what about factory reset?
              • paulrid
                • Nov 2011
                • 206
                You need a working screen.
