FS-529 Mis stapling
  • pern2808
    • Sep 2015
    • 17
    [Misc] FS-529 Mis stapling
    Hi all, a customer has a FS-529 Internal Finisher which is missing only the last staple, all other sheets get stapled fine. This is regardless of whether stapling 2 sheets or 5 sheets it is always the last sheet that doesn't get aligned properly for stapling. This happens whether it be portrait / landscape or top left only staple or double staple! Checked paddles and the usual but cant see any issues that stand out. Has anyone come across this before as this is a first. Always the last sheet only. Help appreciated as its driving me nuts. Thanks
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: FS-529 Mis stapling
    2 little narrow clear mylars that hang down in the middle - rip em off, problem solved.
    Cant be more specific don't have any of these left in the field and havent seen one for ages. It was a very common problem though.
    • pern2808
      • Sep 2015
      • 17
      Thanks, will give that a go today. Appreciated for the reply!
      • pern2808
        • Sep 2015
        • 17
        Spot on worked a treat. Problem solved. Have attached a photo of offending item for others suffering!
