hello everybody
i have a problem with tray 1 in ineo+454e machine i could not change the type of paper or print out recto verso using it , it only prints recto prints
as you see here there is a type of paper selected but i can't change it !!
when i select tray 1 to change settings i couldn't as you can see :
but the other tray works just fine !!
any suggestion would be appreciated i have the same problem in two machines i tried updating firmware in one of theme but with no luck in fixing this !
