Fault as per title, machine is creasing A3 but only on the bottom half of the page but only from tray 1.
Put paper into tray 2 and it works fine on both single sided and duplex.
Fitted new feed & seperation rollers to tray 1 and swapped with rollers from tray 2, No different.
Trays 1 & 2 prefeed adjustments are linked so it cannot be that, and fuser speed adjustment has no effect either. Tried at both extremes +20 & -20 still the same.
Only thing I can think to try next is tray 1 feed assembly complete as I think the clutch is part of this unit, unless anyone has any other ideas ?
Any input appreciated
