+25 (c25)
  • CrapAimer
    • 296
    +25 (c25)
    Is the admin password for the same for the +25 as the +35 i have it as 12345678. Cant get in ?
    Any help appreciated
    george
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: +25 (c25)
    you have 3 attempts to get it right, after which point you need to restart the machine at the main switch to start the count again. it will reject even the correct password if the count has been exceeded.
    from memory 1-8 is correct, or is it 8 zeros, either way its one of the 2, make sure you are typing numbers.
    • majx75
      • Nov 2014
      • 13
      Re: +25 (c25)
      also try 92729272...that may work as well...
      • mo0651
        • 1054
        Re: +25 (c25)
        It is 12345678. But you have to punch it in like an old cell phone! and scroll thru to the numbers!
        • Hansoon
          • Sep 2007
          • 3389
          Re: +25 (c25)
          Well, don't want to argue with you guys but have one BH-C-25 standing just beside me here having as the web interface password "administrator"
          Hans
          • allan
            RTFM!!
            • 5462
            Re: +25 (c25)
            000000
            utility - select - admin - select - 000000
            Whatever
            • habik
              • 2013
              +25 (c25)
              administrator
              Sent from my iDon't believe in marketing device using Tapatalk
              Firmwares HERE
