Konica 501 with C-3201 code
  • dustzona
    • Mar 2015
    • 83
    [Error Code] Konica 501 with C-3201 code
    The fuser looked ok and turned freely . How likely is it that the drive motor has gone bad ? I'm not to experienced on this machine. Anything will help.
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Konica 501 with C-3201 code
    Check the motor and the drive gears, they are cheap and break pretty easily on this model. You can swap the motor with another similar one in the machine and if the code changes, you have a bad motor.
