Have a 501 that is giving me a c3201 code . thought it was a problem with the fuser drive motor, so i relplaced it . Motor is still not moving at all. I don't have a manual for this model .Where are the test points on the board connector for voltage and signal? Is there some other reason that the motor is not turning? thanks
Konica bizhub 501 C3201
Re: Konica bizhub 501 C3201
Is the fixing unit able to move freely if you try to turn it by hand?
A suggestion from KM:
CAUSE: Inadequate lubrication of the fixing (fusing) unit gears, which prevents the fixing motor from turning at the proper speed.
SOLUTION:
1. Remove the fixing unit, disassemble the input gear assembly, and clean the factory lubricant from gear bores and shaft. Reassemble after applying a suitable high temperature grease. If error code reoccurs, please replace the Fixing Input Gear assembly (p/n 50GA -546 1).
Check your PM for a manual. -
please check the gear unit which drive the fuser unit , please check the fusing motor on load check ,if its work there should be damage in gears...Comment
