i know this code is fixing error code , but i check the lamp ,thermostat is ok and try to reset with Dip swicth 25-3 to 0 .but still error code . please help thanks
Replace temp sensors which is a common issue with that model series, Of course that's after you reset the code. I would print out a failure list to see if the machine has a history of the code, then make a judgment call on the sensors.
